STM32 MCUs
From FAQs to complete How-to articles, find useful articles on STM32 MCUs programming, troubleshooting, ecosystem, and product details.
Knowledge Base Articles
How to create an STM32N6 FSBL load and run
Summary The first stage bootloader (FSBL) is a key component in the boot process of STM32N6 microcontrollers. It is responsible for initializing the system, configuring the hardware, and loading the application code from external memory into the int...
FSBL_SimpleLoadAndRun.gif FSBLAndApp.gif BMontanari_2-1738343101105.png BMontanari_3-1738343101107.png
How to configure the linked list mode in STM32CubeMX
Introduction This article provides a step-by-step guide on configuring the GPDMA linked list in STM32CubeMX. It does not cover the legacy standard DMA approach, which is described in the article "How to configure the GPDMA." 1. Software prerequisite...
Icache config.png GPDMA config(all channels).png GPDMA config(ch0).png linked_list_Queue_Config.png
Sarra.S by ST Employee
  • 4627 Views
  • 5 comments
  • 2 kudos
How to debug STM32N6 using STM32CubeIDE
Summary This tutorial is a comprehensive guide for debugging code from external serial flash on the STM32N6. It covers: setting up the environment, configuring the debugger, and validating the setup. Introduction To debug the code running from the e...
BMontanari_0-1746721362224.png BMontanari_1-1746721390464.png BMontanari_2-1746721418605.png BMontanari_3-1746721449634.png
How to use semihosting with STM32CubeIDE and STM32
Summary Semihosting can be used to enable code running on STM32 to communicate with the host computer during a debug session. This makes it possible to use host computer I/O (for example keyboard, display, or file system) instead of having such input...
LauraCx by ST Employee
  • 24813 Views
  • 6 comments
  • 5 kudos
Lightweight EEPROM emulation
Summary This article provides a step-by-step description of a lightweight algorithm to write and retrieve data from flash using virtual addresses. The key aspect is the low footprint and overall simplicity. The code example in this guide is provided...
Domini by ST Employee
  • 709 Views
  • 2 comments
  • 2 kudos
How to connect two quad-SPI memories using only one OCTOSPI
There are two possible solutions for connecting two quad-SPI memories using only one OCTOSPI interface. Solution 1: Use a dedicated bit in the OCTOSPI_CR register for external memory selection: MSEL bit for STM32H5, STM32U5, and STM32L5 series or FS...
KDJEM.1 by ST Employee
  • 2277 Views
  • 5 comments
  • 4 kudos
How to use the LPAWUR range on the NUCLEO-WL33CCx board
The low power wakeup radio (LPAWUR) feature is not enabled by default on NUCLEO-WL33CCx boards. It has been designed for the reception of a specific frame to trigger the wake up of a system. To enable and use the LPAWUR feature on the NUCLEO-WL33CCx ...
Imen.D by ST Employee
  • 268 Views
  • 0 comments
  • 1 kudos
How to debug the STM32N6 using VS Code
Summary This article provides a detailed guide on using VS Code to debug code running from external serial flash on the STM32N6. It covers setting up the development environment, setting up the project with CMake, configuring the debugger within VS ...
BMontanari_0-1756124872300.png BMontanari_1-1756124872303.png BMontanari_2-1756124872310.png BMontanari_3-1756124872310.png
STM32 and FreeRTOS+ CLI library
Introduction In this guide, we explore how to integrate and use the FreeRTOS+ command-line interface (CLI) library to enhance your embedded applications. Designed for ease of use and flexibility, the FreeRTOS+ CLI allows developers to create robust c...
managesoftwarepacks.png freertos.png selectComponents.png softwareselector.png
Reset management on the NUCLEO-WBA55CG
The NUCLEO-WBA55CG with MB1801-NoUSB-D02 has a different configuration for reset management compared to earlier versions. In the default configuration, the reset via mass storage and the reset via debugging tools are disabled, which may cause issues...
STTwo-32 by ST Employee
  • 378 Views
  • 1 comments
  • 1 kudos
How to run AI models from model zoo on STM32N6
Summary This article provides a comprehensive guide on running AI models from the STM32 model zoo on STM32N6 microcontrollers. It includes step by step instructions on selecting a model, preparing the development environment, and converting the mode...
BMontanari_0-1750274125242.png BMontanari_20-1750274393361.png BMontanari_21-1750274421046.png BMontanari_22-1750274431052.png
How can I add TraceX support in STM32CubeIDE?
To add TraceX support to a STM32CubeIDE project and properly use it you’ll need to follow a few steps, described in detail in this article. Goal: Add TraceX support to STM32CubeIDE using X-CUBE-AZRTOS-H7Although the example is using the NUCLEO-H723ZG...
How to set up Sigfox on STM32WL3x
Introduction This article explains how to set up Sigfox connectivity on the STM32WL3x microcontroller. Sigfox is a low-power wide-area network (LPWAN) technology designed for IoT applications requiring long-range and low-energy communication. By fol...
  • 531 Views
  • 0 comments
