2024-03-22 8:30 AM - edited 2024-03-22 8:52 AM
2024-03-22 9:47 AM
Dear @mathieuM ,
Thank you for the question, I do not have a board now to check, but Indeed I confirm that RevX is the latest revision in production and fixes few major limitations - you can see in the first table between A, Z and X. May be you hit this Knowledge Article case as that @Address is impacted by RO data if you can check and let me know : How to avoid a hard fault when ICACHE is enabled o... - STMicroelectronics Community
Hope it helps You.
STOne-32
2024-03-22 9:47 AM
Dear @mathieuM ,
Hope it helps You.
STOne-32
2024-03-22 11:24 AM
I tested what is recommended in the link you sent, and it fixed the issue.
The HardFault was indead created because of the ICACHE and access to RO memory areas.
Thank you so much for your quick response!
Best,
MM
