I2C with DMA not working
‎2024-07-01 1:00 AM
I'm somewhat new to STM32. I need to use DMA to collect data from a tempreture sensor over I2C.
My sensor is an Adafruit MCP 9600 and I'm using a Nucleo F446RE board. Following is the code I use. Can someone help as I've been stuck here for days without knowing what to do.
uint8_t TMP_ADDR = 0x65 << 1;
uint8_t TMP_REG = 0x00;
uint8_t TempReading[100];
void MCP9600_ReadTemperatureDMA(void)
TempReading[0] = TMP_REG;
if (HAL_I2C_Master_Transmit(&hi2c1, TMP_ADDR, TempReading, 1, HAL_MAX_DELAY) == HAL_OK) {
if (HAL_I2C_Master_Receive_DMA(&hi2c1, TMP_ADDR, TempReading, sizeof(TempReading)) == HAL_OK) {
HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_SET);
// I2C DMA Transfer Complete Callback
void HAL_I2C_MemRxCpltCallback(I2C_HandleTypeDef *hi2c)
HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_RESET);
DMA
I2C
STM32F4 Series
‎2024-07-01 3:58 AM
There is option in Mx tool , open ioc file. Look for dma type , select normal.
‎2024-07-01 1:59 AM
I2C without DMA works?
Start perhaps with bit-banged I2C to check if the connections are OK.
What are values of pullup resistors?
‎2024-07-01 2:57 AM
hey,
Thanks for the reply.
1. Yes. it works and gives me tepreture reading.
2. I am not using any external pullups. Am I supposed to use it like that?
‎2024-07-01 3:15 AM
I2C typically expects them. Internal pull-ups on STM32 pretty weak and slow, especially if presented a relatively large capacitive load..
Get a scope or logic analyzer on the signals to better understand what's happening.
You work with people with related competencies? Manager, supervisor, colleagues?
‎2024-07-01 3:16 AM
Can you try with Normal dma setting. You are triggering dma every time.
‎2024-07-01 3:18 AM
DMA and IT routines return immediately, watch for error returns and longevity of data contexts/scope passed to routines. ie not auto/local to calling subroutine.
‎2024-07-01 3:20 AM
Thank you for the answer. I will try with external pullups.
No, I'm learning this on my own.
‎2024-07-01 3:21 AM
Thanks for the reply. But can you please explain it a little bit more?
‎2024-07-01 3:34 AM - edited ‎2024-07-05 6:57 AM
@sadeepTA wrote:2. I am not using any external pullups. Am I supposed to use it like that?
Pullups are fundamental to the operation of I2C.
@sadeepTA wrote:My sensor is an Adafruit MCP 9600
The MCP9600 is a Microchip product: https://www.microchip.com/en-us/product/mcp9600
I presume you mean this Adafruit "breakout board" - which features the Microchip MCP9600:
https://learn.adafruit.com/adafruit-mcp9600-i2c-thermocouple-amplifier
So the question becomes: does that board provide the required pullups?
The schematics are here:
https://learn.adafruit.com/adafruit-mcp9600-i2c-thermocouple-amplifier/downloads
and show that pullups are, indeed, provided on the board:
#Pullups #I2CPullups
‎2024-07-01 3:58 AM
