Calculate ARR value for Timer TIM2, TIM3 in STM32F407
Hi
Can you tell me how I can calculate a value for ARR for timer 2(32bit timer) and timer3(16bit timer)
I am using STM32F407 APB1 timer clock is 12MHz prescaler is 6
gbm
gbmBest answer
Read The Fine Document - the Reference Manual, GPIO section. The only register needed for simple output setup is MODER; you don't need to touch the others.
Regarding the timer setup: why should you calculate the values? Leave it to the compiler. For simple timebase setup:
#define TIMCLK_FREQ 84000000u
#define TIM_PERIOD_us 1000u
TIMx->PSC = TIMCLK_FREQ / 1000000u - 1;
TIMx->ARR = TIM_PERIOD_us - 1;
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
mƎALLEm
For which purpose? time base?
Inspire from:
https://github.com/STMicroelectronics/stm32f4xx-hal-driver/blob/4ae1c83b8aa574042fee644688d406b2429a95d6/Src/stm32f4xx_hal_timebase_tim_template.c
 /* Get clock configuration */
 HAL_RCC_GetClockConfig(&clkconfig, &pFLatency);
 /* Get APB1 prescaler */
 uwAPB1Prescaler = clkconfig.APB1CLKDivider;
 /* Compute TIM6 clock */
 if (uwAPB1Prescaler == RCC_HCLK_DIV1)
 uwTimclock = HAL_RCC_GetPCLK1Freq();
 else
 uwTimclock = 2 * HAL_RCC_GetPCLK1Freq();
 /* Compute the prescaler value to have TIM6 counter clock equal to 1MHz */
 uwPrescalerValue = (uint32_t) ((uwTimclock / 1000000U) - 1U);
 /* Initialize TIM6 */
 TimHandle.Instance = TIM6;
 /* Initialize TIMx peripheral as follow:
 + Period = [(TIM6CLK/1000) - 1]. to have a (1/1000) s time base.
 + Prescaler = (uwTimclock/1000000 - 1) to have a 1MHz counter clock.
 + ClockDivision = 0
 + Counter direction = Up
 TimHandle.Init.Period = (1000000U / 1000U) - 1U;
 TimHandle.Init.Prescaler = uwPrescalerValue;
 TimHandle.Init.ClockDivision = 0U;
 TimHandle.Init.CounterMode = TIM_COUNTERMODE_UP;
 TimHandle.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
 status = HAL_TIM_Base_Init(&TimHandle);
See also the application note AN4013 "Introduction to timers for STM32 MCUs " / section 2.2 Time base generator
Andrew Neil
can you show what should be the purpose of each timers?
If you have timer clock on 12 MHz and prescaler is 6 the timer counter will be counted with frequency
12 MHz / (6+1) = 1.71 MHz. ARR register defines when timer counter will be reloaded. Frequency of reloading the timer counter is calculated as: 1.71 MHz / (ARR+1) in this case.
Ash1Author
Hi
I will again refreshed my query my APB1 timer clock is 72Mhz so does it mean my timer are running on 72Mhz?
prescaler value which I said earlies it was CAN prescaler so plz ignore previous query.
second I want to create a delay like 10millisec 100millisec e.g every 10ms interrupt will generate.
for explanation you can take any 10ms ,100ms
note: at the time of Timer_Initialization I loaded ARR value with 0xFFFFFFFF and Counter value with 0x00000000
auto preload is disabled.
and at runtime time I am want to change ARR value with desired value I am using upcounter. so i want to know what will prescaler value and method to create a delay.
Andrew Neil
See the Reference Manual - that will show how the timer's counter is clocked.
See also the clock configuration in CubeMX.
So that's a Timebase - as illustrated by @mƎALLEm
