2018-12-06 01:46 AM
but on https://www.st.com/content/st_com/en/products/microcontrollers/stm32-32-bit-arm-cortex-mcus/stm32-mainstream-mcus/stm32g0-series/stm32g0x1.html?querycriteria=productId=LN2048 there is no mention of USB HOST/DEV, not even in the future products.
Is this some oversight, or are 'G0x3 with USB planned?
PS. Can that picture on website be provided in higher resolution, please?
2018-12-06 09:15 AM
USB HOST/DEV is not supported yet, but the part number supporting it will arrive rapidly.
Kind Regards,
Imen
2018-12-06 02:09 AM
The G0 series looks like an overhaul of F0. STM32F071 also has no USB, only F072 has. Hopefully a G072 is planned. I Expect the mention of USB on G071 is an error.
2018-12-06 09:15 AM
Kind Regards,
Imen
2018-12-06 03:06 PM
Thanks, Imen, for the info.
Jan
2019-10-29 01:43 PM
OK. IT's been a year... "Can I has USB?"
Still no G0x3 with any USB?
2019-10-30 03:00 AM
Hi @kyrreaa ,
It is in development, target end of next year in mass production.
Best Regards,
Imen
2019-11-14 08:09 PM
So when you said "the part number supporting it will arrive rapidly", you meant 2 years?
2019-11-15 12:28 AM
Hi, the USB is planned in the G0 series by Q2 next year. If you need both USB PD and USB data in your design, I suggest you to have a look on the STM32G4x1 value line series that support those functionalities. Best regards.
2019-11-15 12:58 AM
Hi Jean-Philippe @JDUMA ,
Thanks for the info.
The G4x1 have only USB Device. As shown in initial post, the G0 is promised to have HOST/DEV, is that true? If so, will it be again the Synopsys OTG, or something different?
Thanks,
Jan
2019-11-15 01:04 AM
Hello
please have a look on the STM32G4 datasheet . It has both USB 2.0 FS data interface and USB PD.
BR, JP
