ST25 NFC/RFID tags and readers
Ask questions and find answers on ST25 NFC/RFID tags and readers, including connectivity implementations and antenna design.
Resolved! Problem with ST25R Antenna Matching Tool
 Hello everyone, for my project I am using the X-Nucleo-NFC08A1 board. In addition, I am using an external antenna that I operate differentially. The antenna is connected to the board via an SMA connector. I know that I should also adjust the matchin...
Resolved! Access Levels for ST25 Tags
Good morning, currently I'm working on this task is to set the tag to have a different access levels.I downloaded IOS "NFC Tap" App to try out and there's this feature called, "Area Security Status".My question is,for "Readable, write protected by pa...
MaoFeng by Associate II
  • 746 Views
  • 1 replies
Resolved! ST25 NAK after 3 commands
Hello,I have a really weird behaviour for my chip which I can't really figure out. Basically, I am using only the commands from the ST25DV library (st25dv discovery board).After 2 function calls (for example present password and disable RF) the subse...
robertp by Associate II
  • 3067 Views
  • 7 replies
Resolved! STSW-ST25SDK001 ST25DemoApp Example Issue
Good afternoon, currently I want to write a simple NDEF File in the tag's EEPROM by using ST25R3916-DISCO kit.I will attach the guide pdf, "ST25PcDemoApp_software_guide" at below for reference.I faced this problem after I added JARs into "Java Build ...
  • 2148 Views
  • 3 replies
Resolved! NFC07A1 antenna design
Do you have the antenna size and design process reference of NFC07A1? I want to know how to match the circuit and what is the inductance of the antenna.
Resolved! How to choose 13.56MHz antenna for ST25DV64KC
Hi,I designed a board with NFC Chip ST25DV64KC, which will be connected with a extra antenna, during the selecting of antenna products, one parameter confuses me very much: the self-Resonance Frequency, is it important? For example this product. Or a...
