Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Resolved! A6727 design concern
 I'm using E Design Suite to build a buck (step-down) converter circuit and would like to know if there's anything in the design that I should be concerned about. I've reviewed the schematics in the datasheets, and they seem to be about the same.I pl...
Resolved! Is the documentation for TDA7786 complete?
I found that the TDA7786 provides a datasheet, but based on others' code, it seems to lack a lot of content. Are there any similar technical reference documents or application manuals? I feel like I can't write the driver based solely on the datashee...
Shiina by Associate III
  • 919 Views
  • 1 replies
Resolved! STPM4RasPI HMAC authorization
Hello, I'm testing HMAC authorizations following TPM 2.0 library specification, and I've confirmed all cases works well except the "unbound and unsalted" session case, which uses null buffer as sessionKey with authValue_entity for HMAC calculation.​I...
skim by Associate
  • 864 Views
  • 1 replies
Resolved! Which is better: ESP32 or other?
Hi everyone!I’m completely new to microcontrollers and planning to start a simple project, maybe something like a motion sensor for my garage or home. I’ve been looking into ESP32 but I’m not sure. Do you have another option you'd suggest?I’d like so...
Sem_Moris by Associate II
  • 3539 Views
  • 7 replies
  • 8 kudos
