Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
unable to compile stm8 using cosmic compiler?
I'm using the Cosmic Software 4.4.9.0 in ST Visual Develop 4.3.12  I can't compile it.I try to install again but it showing same error.i tried to set root path correct like this C:\Program Files\COSMIC\FSE_compilers\CXSTM8.Can any one help me to solv...
tvenk by Associate II
  • 832 Views
  • 0 replies
I am using STEVAL-ILD004V2 source code for dimmer. I can compile using my ST Develop using STM8 cosmic compiler when no change. But, when I change MCU to STM8S103F3P. I will have this compile problem below. Regards, Walter
----------- Project ild004v2 - STM8 Cosmic - Configuration Debug -------------Compiling watchdog.c...cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild0...
WMaca by Associate II
  • 1768 Views
  • 3 replies
LTSpice simulation of STD13N60M2 mosfet
Hello, I've downloaded the provided .lib file for p/n STD13N60M2 and created a part for it in LTSpice, but am not having any luck getting it to work correctly. I've created a circuit with a half bridge and get the expected results when using the mode...
JTurn.3 by Associate
  • 1415 Views
  • 0 replies
  • 1 kudos
Macros of EEPROM emulation return wrong answer
Hello,I currently work with an STM32L496ZG chip and the EEPROM emulation driver (download on https://www.st.com/en/embedded-software/x-cube-eeprom.html).In the "eeprom_emul.h" file, we have the next macro :#define PAGE_ADDRESS(__PAGE__) (uint32_t)(...
APapa.16 by Associate
  • 942 Views
STM8 STUDIO doesn't work
Hello to everyone, when I get started recording session, it runs for few seconds then it stops and I need to restart. Someone has sort this issue out? ThanksFabio (english and italian)
fcasa.16 by Associate II
  • 651 Views
  • 0 replies
STM8L051
Hi, I am not sleeping this microcontroller. I search example code but I couldnt find it please help me. Thanks.
KKURT by Associate II
  • 1592 Views
  • 5 replies
