Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
About STM8S Flash block write
The chip I use is STM8S003F3. When using Flash block erase, it is executed in RAM. If the offset of the Flash address is used with a 32-bit variable, the execution will cause an error. Can this 8-bit microcontroller use 32-bit addressing in RAM?
LXiao.11 by Associate
  • 818 Views
  • 0 replies
Hello, I would like to read and write an ST90402C6 mcu and i own a jegger flasher 5 but i cant choose this mcu model. I can select only ST92F120 ST92F124 ST92F150 ST92F250. If anyone knows of any other way to be able to read this chip? Thank you
Hello, I would like to read and write an ST90402C6 mcuand i own a jegger flasher 5 but i cant choose this mcu model. I can select only ST92F120ST92F124 ST92F150ST92F250.If anyone knows of any other way to be able to read this chip?Thank you
Jcloa.1 by Associate
  • 1142 Views
  • 1 replies
Details on STM8 chip ID and memory size?
Hi,I am the author of an OS tool flash tool named "stm8gal" for programming the STM8 via the ROM bootloader. Currently I check family type and memory size by probing different addresses. This is extremely ugly and may fail in devices I couldn't test ...
GIcki by Associate II
  • 801 Views
  • 0 replies
Resolved! Can't build code of STM8S103F2P6 using STVD and COSMIC
Hello​I want to rewrite code into STM8S103F2P6.​​But I can't build it.​STVD outputted following error massage.​​​Compiling stm8_interrupt_vector.c...cxstm8 +mods0 +debug -pxp -no -pp -l -istm8s_stdperiph_driver\inc -i"C:\Program Files (x86)\COSMIC\FS...
TNaka.7 by Associate
  • 1252 Views
  • 1 replies
