Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
Fault in STM8S/A Standard peripheral library
Hello,I am working with the CAN peripheral on the STM8AF5288.When I was using the standard peripheral library (delivered by STM) I found a fault in the code. It is about the STSW-STM8069 with version 2.3.1. (https://www.st.com/en/embedded-software/st...
Birdo by Associate II
  • 1457 Views
  • 1 replies
Getting PWM counter value at STM8S003F3.
Our customer need some help to develop their application using STM8S003F3.They are using Timer 1 as PWM generator at 125kHz but, does't have success to implement a overflow counter. They told us that the PWM pulse generator are working well. Did you ...
MNasc.1 by Associate
  • 1711 Views
  • 1 replies
Interrupt continuously coming in EXTI interrupt handler after clearing the interrupt .also interrupt is not occurring on both edges . only falling edge triggering is working. Can you give me solution to this problem ?
I am using STM8L152R8 development board. I have configured push button interrupt on Pin no. PG6. i required both edges interrupt . but interrupt is occurring on falling edge only .Can you give any suggestion to this problem.?can you suggest me a...
DJosh.0 by Associate II
  • 6558 Views
  • 12 replies
I start work on a this uC: STM8L052C6, Where i can find a good tutorial to understand and programming this uC with good example, very simple to understand the the various library e peripherals of the uC?
I already download the documentation from this website: https://www.st.com/content/st_com/en/products/microcontrollers-microprocessors/stm8-8-bit-mcus/stm8l-series/stm8l-value-line/stm8l052c6.html#documentationBUT THEY ARE REALLY REALLY BAD THEY ARE ...
NMart.4 by Associate
  • 1353 Views
  • 1 replies
