LED5000
james_chiu
Posted on June 09, 2015 at 10:44
My customer wants to use A/LED5000 to design Automotive lighting
Vin=10~30V, Vout=30V/1.4~1.5A, LED=CREE XLamp XP-G2 series(Vf=3V, If?1.5A)
It's possible to use Floating Boost circuit to design LED5000 on this project or any suggestion?
James Chiu from Distributor, Yosun
#led-driver
sansindhu7794
Posted on November 20, 2016 at 08:51
Hi Team
Can you share any efficiency data for LED5000 based floating boost application.
it will very appreciable if anyone can share the design documents with efficiency test result.
Sandeep Sindhu
