Others: hardware and software
Discuss hardware and software design challenges, including NOR flash storage, OTA updates, component ID, and thermal management.
M95020 not writing some bytes
I am trying to use the M95020 (M95020-WMN6TP to be exact) to replace older 2K SPI EEPROMs. Comparing everything in the data sheets seems to imply it should be a good replacement, with most tolerances higher than the old EEPROM.Yet for some reason, so...
Separate CSV files in SD card by NAME
Hy guys, I'm having some issues trying to come up with a solution to separate CSV files in an SD card by name.My intention is that every time I turn on my board, it compares if there's already a file with that name, if so, it creates a differente one...
FPicc.1 by Senior
  • 1157 Views
  • 0 replies
