Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
VL53LCX Gesture Recognition for Linux
I have used the VL53LCX Linux driver to operate the ToF sensor on the IMX8M Nano board, and the Linux driver is functioning correctly. However, I am encountering issues with implementing gesture recognition functionality. I have used the gesture reco...
VL6180 part to part variation
Hi all,         What is the part to part variation of ST VL6180 ToF sensor? During testing, we keep the sensor at a distance of 50mm from a retro reflector tape. In a batch of 50 sensors, the readout was from ~ 37 mm to  ~51 mm (expected readout is 5...
Syam by Associate II
  • 2141 Views
  • 3 replies
  • 1 kudos
Resolved! Adding multiple vl53l0x sensors
Hi allI have successfully implemented a single vl53l0x sensor, but wish to add more. I found the "AN4846 Application note Using multiple VL53L0X in a single design" documentation:https://www.st.com/content/ccc/resource/technical/document/application_...
ADP1114 by Associate II
  • 17529 Views
  • 30 replies
  • 1 kudos
Resolved! How to filter multitarget readings on ToF sensor
Hello, We've been developing a tank level monitoring system using these sensors: VL53L4CD (18° FoV)VL53L3CX (25° FoV, multitarget)VL53L4CX (18° FoV, multiobject, multitarget) First question is the definitions and distinctions between the terms multiz...
karlacha by Associate II
  • 5231 Views
  • 4 replies
VL53L8CX : firmware loading over SPI fails with timeout
Hello,I'm currently using VL53L8CX with an STM32U535 on a custom PCB.I'm using X-CUBE-TOF1 package.I'm able to identify the sensor with SPI at 2MHz using vl53l8cx_is_alive function.I was able to successfully init and use VL53L8 on U-585I-IOT02A dev b...
josselin_1-1716475677011.png josselin_2-1716475706691.png josselin_0-1716474997218.png
josselin by Associate II
  • 2564 Views
  • 4 replies
Resolved! VL53L8CX changing the data rate
Hi everyone, I am currently using the VL53L8CX for people counting. However, I have encountered an issue where occasionally, changing the data acquisition rate during the data collection process causes a disruption and prevents further data acquisiti...
WeiJia by Associate II
  • 4241 Views
  • 4 replies
Resolved! VL53L0X GPIO1 and ranging sequence
HiI refer to the VL53L0X Datasheet DoclD029104 rev5 page 15 article 2.10 Ranging Sequence.There not a lot descritption in your documentI need to understant how GPIO1 stay down before the sensor pull it up when init/ranging/housekeeping phase is finis...
SCADE by Associate III
  • 1762 Views
  • 1 replies
  • 1 kudos
