Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Caching issue with SPC58
Hi, We're testing an SPC58NN84E7 and encountering an issue with the ADC in DMA mode. Our debugger is an SPD5-UDESTK interfaced via OpenOCD.When inspecting the ADC's DMA result buffer through the debugger, all values appear valid. However, unexpected ...
sacha by Associate II
  • 969 Views
  • 0 replies
SPC5 debug and flash programming
Hello, We are currently developing a board for a customer with a SPC564B74L7 (his choice, not ours). Now we need a tool to debug through JTAG and to program the flash.Is SPC5-UDEDEBG-TL enough? Do we need specific software or should we use STELLARLIN...
SPC58NH-DISP CAN Test Application available?
Hello,We are trying to get setup with the SPC58NH-DISP board and are having issues with getting CAN communication going. I attempted to manually adjust the CAN Bootloader test application to send a simple message over CAN J2 but have not had any luck...
LTrap1 by Associate
  • 829 Views
  • 0 replies
How to access ADC value on GTM/MCS
How to read ADC conversion results on the GTM/MCS.Here is my code:MCS side:AN8  = __brd(0x00005440);AN9  = __brd(0x0000544C);AN16 = __brd(0x00005480);AN17 = __brd(0x00005488);AN26 = __brd(0x000054D0);AN27 = __brd(0x000054D8);AN40 = __brd(0x00005540);...
JAYLOU by Associate II
  • 811 Views
  • 0 replies
SPC58EC-DISP USB to Serial connection
I want to read and write data by serial connection.For test, I import samples "SPC58ECxx_RLA SERIAL Test Application for Discovery" from application library.In my understanding, the "main.c" function write "Hello World!" by serial connection.my envir...
jchoi.1 by Associate
  • 3010 Views
  • 3 replies
Machine check interrupt ( SPC58NE84C3)
Hi,I am using:Processor: SPC58NE84C3Compiler: FreeGCCWe have a working software setup running with optimization level "O0". However, when we enable "O1", we encounter issues in certain states where it triggers the the Machine Check Interrupt (offset ...
febe2 by Associate II
  • 1200 Views
  • 0 replies
ISR registration
I am using sample example from SPC58NN84E7, I could see there is common ISR function for all the modules, of course with different vector number, But i am not able to see how this   #define IRQ_HANDLER(id) void id(void) function address is registered...
CFG_2.FR_ADJ Bit Discrepancy in L9800 Datasheet
Hello,I have a question regarding the L9800 product (LS driver). The value of the CFG_2.FR_ADJ bit in "Table 12. Coefficient overview" differs from the value of the CFG_2.FR_ADJ bit in "Table 18. Register addressing space" in the datasheet. Could you...
swbae by Associate
  • 890 Views
  • 0 replies
