STM32CubeProgrammer V2.16 DFU Download Problem
TKana.1
Updated from 2.15 today. Having DFU download problem seen attached.
Board is recognised but upper right still stated as "Not connected" and download fails.
Downgraded to V2.15 and same board connects and downloads OK.
OS: W10 64bit
Board: STM32F767NI custom
Fyi
Timucin KANATLI
STTwo-32
Hello @TKana.1
Issue has been solved on the Last version of the STM32CubeProgrammer (V2.17.0).
Best Regards.
STTwo-32
5 REPLIES 5
STTwo-32
Hello @TKana.1
Are you having the same problem as mentioned on the following post:
STM32CubeProgrammer 2.16.0 fails to program STM32L... - STMicroelectronics Community
Best Regards.
STTwo-32
Exactly. Mine works on V2.15
Best Regards,
Tim
I've added your problem to the ticket created for the post mentioned on my first Comment. We will be back to you as soon as there is any News.
Best Regards.
STTwo-32
STTwo-32
Hello @TKana.1
Best Regards.
STTwo-32
2.17 works OK with StlinkV2 firmware V2J45S7.
Meantime, don't understand why 2.15 updater as of today still shows "no updates available". See attached
Best Regards,
Tim
