STM32CubeProgrammer incorrectly displays BKPSRAM content
Below CubeProgrammer's window is gdb displaying the real content of BKPSRAM.
Mike_ST
Hello Jan,
Go to memory editor part (the same one you shown on the picture), enter the reg address and write desired reg value.
12 REPLIES 12
Mike_ST
Thank you.
Ticket entered...
Hi @Mike_ST​ ,
Thanks.
Jan
Mike_ST
Hello Jan,
I got feedback...
It seems like in the GDB setup you are using the BKPSRAM has been activated previously,
When STM32CubeProgrammer is only reading memory without doing activation.
Hi Mike,
What do you mean by *activation* here, in terms of the Reference Manual?
And what should I do to "activate" the BKPSRAM so that it is readable by CubeProgrammer?
Thanks,
Jan
@Mike_ST​
Mike_ST
Hi Jan,
RCC.PWREN set to 1
RCC.BKPSRAMEN set to 1
PWR.BDP set to 1
Hi Mike,
Thanks.
So, how do I set those bits in CubeProgrammer, so that I can read out (and eventually reprogram) content of BKPSRAM?
Thanks,
Jan
@Mike_ST​
Mike_ST
Hello Jan,
Hi Mike,
OK, this works. For read, it's enough to set RCC_AHB1ENR.BKPSRAMEN of course.
CubeProgrammer could do this automatically, though, when access to the BKPSRAM area is requested; I don't see any danger stemming from this.
It also could support write in the same manner, besides PWR_CR.DBP perhaps also setting PWR_CSR.BRE (but that should perhaps be optional).
Can this please be chalked up as a feature request to CubeProgrammer? After all, BKPSRAM is a nonvolatile memory, thus similar in usage to FLASH...
Thanks for your support,
Jan
@Mike_ST​
Mike_ST
Hi again,
"CubeProgrammer could do this automatically"
Actually I asked for that in the ticket. It has been rejected, because we want to display original memory/register state.
You can try automate the process by creating a batch script that call STM32CubeProgrammer with the w32 command to set the 3 registers.
STM32CubeProgrammer\bin\STM32_Programmer_CLI.exe -c port=SWD mode=normal -w32 0x40023840 0x10000000 -w32 0x40023830 0x00140000 -w32 0x40007000 0x0000C100
Then you have to connect in "Hotplug" mode, not "Normal" or under "Reset".
