STM32CubeProgrammer connection over UART error
ERazz.3
Hi, I've some problem using SMT32CubeProgrammer.
i am trying to connect via uart to micro stm32g491 but i receive some error messages.
15:21:34:034 : RTS low
 15:21:34:034 : DTR low
 15:21:34:171 : Serial Port COM15 is successfully opened.
 15:21:34:172 : Port configuration: parity = even, baudrate = 115200, data-bit = 8,           stop-bit = 1.0, flow-control = off
 15:21:34:172 : No Init bits value is : 0
 15:21:34:172 : Sending init command:
 15:21:34:175 : byte 0x7F sent successfully to target
 15:21:34:176 : Wait ends after 1 loop, dataready = 1, delay = 0
 15:21:34:176 : Received response from target: 0x79
 15:21:34:191 : Activating device: OK
 15:21:34:192 : Sending GetID command and its XOR:
 15:21:34:192 : byte 0x02 sent successfully to target
 15:21:34:192 : byte 0xFD sent successfully to target
 15:21:34:192 : Wait ends after 1 loop, dataready = 1, delay = 0
 15:21:34:192 : Received response from target: 0x79
 15:21:34:192 : Received 4 data bytes from target : 0x03047b7b
 15:21:34:194 : Chip ID: 0x47B
 15:21:34:195 : Sending Get command and its XOR:
 15:21:34:195 : byte 0x00 sent successfully to target
 15:21:34:195 : byte 0xFF sent successfully to target
 15:21:34:195 : Wait ends after 1 loop, dataready = 1, delay = 0
 15:21:34:195 : Received response from target: 0x7b
 15:21:34:196 : Error: GET command not acknowledged!
 15:21:34:197 : Reemission of Get command
 15:21:34:197 : Sending Get command and its XOR:
 15:21:34:197 : byte 0x00 sent successfully to target
 15:21:34:214 : byte 0xFF sent successfully to target
 15:21:34:214 : Received response from target: 0x1b
 15:21:34:215 : Error: GET command not acknowledged!
 15:21:34:218 : Reemission of Get command
 15:21:34:218 : Sending Get command and its XOR:
 15:21:34:222 : byte 0x00 sent successfully to target
 15:21:34:224 : byte 0xFF sent successfully to target
 15:21:34:226 : Received response from target: 0x33
 15:21:34:228 : Error: GET command not acknowledged!
 15:21:34:328 : UART PORT CLOSE
but if I try to communicate with the embedded bootloader of stm32 using another software (for example minicom or docklite) I can communicate correctly.
here are some messages on the serial:
09/03/2022 14:37:50.788 [TX] - 7F
09/03/2022 14:37:50.804 [RX] - 79
09/03/2022 14:37:51.966 [TX] - 02 FD
09/03/2022 14:37:51.971 [RX] - 7A 03 04 7B 3F 79
09/03/2022 14:37:53.091 [TX] - 01 FE
09/03/2022 14:37:53.094 [RX] - 79 33 00 00 7B 3F
09/03/2022 14:37:53.787 [TX] - 02 FD
09/03/2022 14:37:53.793 [RX] - 7B 3F 03 04 7B 7B 3F
09/03/2022 14:37:54.490 [TX] - 01 FE
09/03/2022 14:37:54.497 [RX] - 79 71 00 00 7B 3F
why can't i use stm32cubeprogrammer software?
Houda GHABRI
Hi @ERazz.3​ ,
I tested with the same device you have (same Device ID and Bootloader version), it works fine on ST Board with both CubeProgrammer 2.9.0 and 2.10 version.
So I suspect a wiring issue , you can try to reduce the Baudrate and test again?
Houda
12 REPLIES 12
Houda GHABRI
Hi @ERazz.3 ,
Are you using the last CubeProgrammer version 2.10.0.? If not can you please switch to this version which contain many enhancement related to UART connection?
Houda
ERazz.3
i've installed stm32cubeprogrammer 2.10.0.
it seem to be the same...
here the log.
14:29:04:255 : Activating device: OK
14:29:04:256 : Board : --
14:29:04:256 : Sending GetID command and its XOR:
14:29:04:257 : byte 0x02 sent successfully to target
14:29:04:260 : byte 0xFD sent successfully to target
14:29:04:260 : Wait ends after 1 loop, dataready = 1, delay = 0
14:29:04:306 : Received response from target: 0x79
14:29:04:306 : Received 4 data bytes from target : 0x01047b79
14:29:04:307 : Chip ID: 0x47B
14:29:04:307 : Sending Get command and its XOR:
14:29:04:309 : byte 0x00 sent successfully to target
14:29:04:312 : byte 0xFF sent successfully to target
14:29:04:312 : Wait ends after 1 loop, dataready = 1, delay = 0
14:29:04:312 : Received response from target: 0x6f
14:29:04:313 : Error: GET command not acknowledged!
14:29:04:313 : Reemission of Get command
14:29:04:313 : Sending Get command and its XOR:
14:29:04:314 : byte 0x00 sent successfully to target
14:29:04:316 : byte 0xFF sent successfully to target
14:29:04:316 : Received response from target: 0x61
14:29:04:316 : Error: GET command not acknowledged!
14:29:04:317 : Reemission of Get command
14:29:04:317 : Sending Get command and its XOR:
14:29:04:317 : byte 0x00 sent successfully to target
14:29:04:317 : byte 0xFF sent successfully to target
14:29:04:318 : Received response from target: 0xee
14:29:04:318 : Error: GET command not acknowledged!
14:29:04:341 : UART PORT CLOSE
Houda GHABRI
Hi @ERazz.3​ ,
Ok I will check , can you tell me if you are using CLI or GUI? If CLI command line used please.
Houda
ERazz.3
@Houda GHABRI​  i'm using GUI.
Houda GHABRI
Hi @ERazz.3​ ,
I did same checks using NUCLEO-G491RE board and connection via UART works correctly.
I see in your traces that the Device ID is not correct :
The correct device ID for STM32G491  is 0x479 so tell me please if you are using an ST Board? Also send me please the Bootloader version of your chip ( value of Bootloader is in 0x1FFF6FFE address).
Houda
Houda GHABRI
Hi @ERazz.3​
The Baudrate value used during connection please?
Houda
Hi, at address 0x1FFF6FFE I see 0xD2.
we're using our custom bord.
thanks
Hi, 155200
Houda GHABRI
Hi @ERazz.3​ ,
Houda
