CubeProgrammer current firmware unknown
jlourencao
How can i solve this ? My board is a nucleo lnucleo-l476rg (genuine i think) but i cant do anything bc my cubeprogrammer dont works
jlourencao_0-1726358904698.pngjlourencao_1-1726358927024.pngjlourencao_2-1726358937302.png
jlourencao
I managed to update the firmware after removing the IDD jumper, but i didn't understand why, since i didn't read anything about having to remove this jumper for this ...
Anyway, thanks guys :) .
3 REPLIES 3
Peter BENSCH
Welcome @jlourencao, to the community!
I haven‘t seen any faked NUCLEO yet, so I assume it’s a genuine one.
Did you tried another USB cable and/or another USB port?
Sometimes these are only charging cables or not suitable for USB data transfer.
/Peter
SofLit
Hello @jlourencao and welcome to the community,
Disconnect and reconnect the cable and try again.
Try to use STLink firmware upgrade downloadable from here: https://www.st.com/en/development-tools/stsw-link007.html
If It doesn't work, use STLINK utility (a depricated tool) to update the STlink firmware,
downloadable from here.
Hope it helps.
PS:
jlourencao
