2024-04-15 07:00 AM
Cant program STM32G031J4 with stm32CubeProgrammer 2.16.0 (bootloader 3.1). It display default flash size of 63Kb and all command have errors ( erase/read/write.....).
2024-04-29 01:04 PM
Hello @Nnabb.1 ,
This issue is fixed in the STM32CubeProgrammer 2.16.0.
STM32CubeProgrammer 2.16.0 released - STMicroelectronics Community
"162313 [STM32G031GU6] Wrong flash memory size of 63 Kbytes instead of 16 Kbytes."
First, I advise you to remove all older versions of STM32cubeProgrammer, and make sure that you are using the latest release.
Then, let me know whether the problem here persists or not.
