2024-04-15 07:00 AM
Cant program STM32G031J4 with stm32CubeProgrammer 2.16.0 (bootloader 3.1). It display default flash size of 63Kb and all command have errors ( erase/read/write.....).
2024-04-29 01:04 PM
Hello @Nnabb.1 ,
This issue is fixed in the STM32CubeProgrammer 2.16.0.
STM32CubeProgrammer 2.16.0 released - STMicroelectronics Community
"162313 [STM32G031GU6] Wrong flash memory size of 63 Kbytes instead of 16 Kbytes."
First, I advise you to remove all older versions of STM32cubeProgrammer, and make sure that you are using the latest release.
Then, let me know whether the problem here persists or not.
2024-04-29 01:04 PM
Hello @Nnabb.1 ,
