Does stm32cubemx not support generate project with makefile?
SChen.11
I try to use STM32CubeMX generate project with makefile, but the option is gray. It's can not select. Does the cubemx not support generate makefile on stm32mp1 platform ?
Olivier GALLIEN
Hi @Community member​ ,
I confirm CubeMX does not support "makefile" project generation for STM32MP15.
Can you elaborate why you want/need to use this format?
Olivier
Olivier GALLIEN
4 REPLIES 4
Olivier GALLIEN
Olivier
Olivier GALLIEN
Hi @Community member​ , thanks for your reply. I want manual build and debug the project on cm4 of stm32mp1. The stm32cubeide sometime have failed or error when debug with cm4.
Olivier GALLIEN
Hi @Community member​,
The issue you are facing with STM32CubeIDE debug have to be understood and fixed.
Can you please elaborate this in another post ?
Thanks,
Olivier
Olivier GALLIEN
Okay, I will post it later.
