CubeMX STM32MP1 NVIC EXTI disabled ?
debugging
Lead
1 Select STM32MP151 (This case AAAx)
2. Select an GPIOx and set to GIPIO_EXTx
3. Goto NVIC: EXTI option is disabled
  (Checkbox cannot be selected)
4. Goto GPIO : Pin can be configured as interrupt
How to enable interrupts for NVIC for GPIO's in order to generate the code ? See pictures. CubeMX 5.3.0, Linux
debugging
Lead
CLOSED, First need right click on the pin and select Cortex M4
4 REPLIES 4
Olivier GALLIEN
Hi @debugging​
it seems you have miss one step :
3.Select again GPIO under Pinout View, right click -> Pin Reserved -> Cortex-M4
4. Goto NVIC: EXTI option checkbox can now be selected
Indeed, this is not obvious and not well documented. We will work to enhance this.
Hope it help
Olivier
Olivier GALLIEN
debugging
Lead
Hello Olivier ,
Many thanks. That worked.
Being on this topic, snipped of the code:
EXTI_ConfigStructure.Trigger = EXTI_TRIGGER_FALLING;
HAL_EXTI_RegisterCallback(&hexti, HAL_EXTI_FALLING_CB_ID, Callback);
But , no matter what, the default handler is called and not the custom function Callback.
Thanks!
Olivier GALLIEN
Hi @debugging​
Could you refer to Cube Package example
STM32Cube_FW_MP1_V1.0.1\Projects\STM32MP157C-DK2\Examples\GPIO\GPIO_EXTI
And check what may be wrong in the IT configuration ?
Olivier
Olivier GALLIEN
debugging
Lead
