2022-07-05 11:37 PM
I like to use the LQFP144 case of the STM32U575, but unfortunatly the case showed is wrong, see attaced pictures
2022-07-06 12:34 AM
Hi @MHo.15llenweger ,
Thank you for your message. 😉
In fact there is no mistake, STM32U575ZGTx is available on LQFP144 package (with SMPS and without SMPS) and with a different pinout.
LQFP144 pinout with SMPS available :
LQFP144 pinout without SMPS, corresponding to your STM32CubeIDE's picture:
Please refer to the section "4: Pinout, pin description and alternate functions" of the attached datasheet.
Best regards,
A.MVE
2022-07-06 12:34 AM
Best regards,
A.MVE
2022-07-06 02:07 AM
Thanks for the answer, Your right, I ignored the existence of two different pin-out's for the same case.
Best regards
Martin
