STM32CubeMx Version 6.11.1 (users in my office can't login via CubeMX)
blimp01
Currently having a frustrating issues where users in my office cannot log in to ST via the Cube. Meaning we have to download it manually. We are not running a proxy. When we try to go to log in we just get a loading screen. On Windows we then get the message Connection Lost.
Please Advise how to trouble shoot
Alister
SofLit
Dear all,
Seems the issue has been solved please check from your side.
PS:
5 REPLIES 5
ALT.1
Our company has the same problem. Does anyone know what the problem is???
norlesh
Don't know when the bozos at ST are going to fix this ridiculous login situation - but for those between a rock and a hard place having to rely on the Cube MX software a workaround is to download and install stm32cubemx-version 6-8-1 (the last version before they started mandating you login to download files) side by side with there new ***. Any firmware packs you update while using 6-8-1 are saved in the same location that subsequent versions look for them.
Roger SHIVELY
Hello @blimp01
This post has been escalated to the ST Online Support Team for additional assistance.
Should anyone else have a similar question about log in issues with STM32CubeIDE, please submit your request directly to the ST Online Support Team at https://my.st.com/ols
Roger
Ghofrane GSOURI
Hello @blimp01
The issue seems to be linked either to the server or the tool network connection settings.
The possibility of having issue with the server is under investigation.
If you are connected to the internet via a proxy, please follow the steps from the article bellow to set the tool correctly.
How to set the network connection parameters for S... - STMicroelectronics Community
KR,
Ghofrane
SofLit
Dear all,
PS:
