STM32CubeMX 6.8.0 and STM32CubeIDE 1.12.0: bug in the use of LL
‎2023-03-17 5:36 AM
Currently, STM32CubeMX 6.8.0, including the one used in CubeIDE, generates an incorrect comparison when using the low layer library (LL) for reset and clock control (RCC) in a project. This happens when you change the peripheral module RCC from HAL to LL in Project Manager > Advanced Settings by clicking on the relevant line and then selecting LL.
void SystemClock_Config(void)
LL_FLASH_SetLatency(LL_FLASH_LATENCY_1);
while(LL_FLASH_GetLatency()!= LL_FLASH_LATENCY_1)
LL_PWR_SetRegulVoltageScaling(LL_PWR_REGU_VOLTAGE_SCALE***);
while (LL_PWR_IsActiveFlag_VOS() == 0) // <-- to be corrected
Explanation:
LL_PWR_SetRegulVoltageScaling() sets bits VOS in PWR_CR1,
LL_PWR_IsActiveFlag_VOS() checks the corresponding bit VOSF in PWR_SR2:
Typically, the return value 0 stands for OK or HAL_OK, so LL_PWR_IsActiveFlag_VOS() returns the correct value, but STM32CubeMX inserts the wrong comparison so that the while loop is never exited on OK.
Temporary fix until this is corrected: after each generation of the code by STM32CubeMX, the mentioned comparison in SystemClock_Config() has to be corrected manually from == 0 to !=0 (line 8 in the snippet mentioned above).
We are very sorry if this is causing you any inconvenience at the moment. We will fix the problem as soon as possible.
- Labels:
RCC
STM32CubeIDE
STM32CubeMX
‎2023-03-17 6:37 AM
Thank you all for your contributions and your detailed explanations.
Issue is reproduced and it has been reported to STM32CubeMX development team .
Internal tickets number: 147617 and 147621 (This is an internal tracking number and is not accessible or usable by customers).
Diane
‎2023-03-17 6:02 AM
Hello @Peter BENSCH​
Can you give me more details about your Workspace (Compoment, Firmware package name and version )
Diane P
‎2023-03-17 6:17 AM
This behaviour was already mentioned in this topic: Update to CubeMX 6.8 adds non-working VOSRDY flag check to SystemClock_Config() on STM32F7 using LL drivers
‎2023-03-17 6:21 AM
@t.decker​ Thanks for pointing out the other thread where it is already in progress.
‎2023-03-17 6:37 AM
Diane
‎2023-12-02 11:33 PM
Diane,
When is the fix expected to be released?
How will you communicate status in the meanwhile?
Cheers,
Joe
‎2023-12-04 12:18 AM
Your answer is actually not a solution. A solution is either the first post here, or an actual fix in the next version.
