stm32cubeIDE 1.12 bug on eclipse, can't copy project with it's cubeMX
SeyyedMohammad
Senior III
By copying project for sake of duplicating them, the subproject cubeMX .ioc file will no longer becomming open.
Also renaming cubeIDE projects will cause anomaly. In front of their name, something tells the folder of project have different name. In standard Eclipse CDT everything done without artifact after renming projects.
5 REPLIES 5
Ghofrane GSOURI
Hello @SeyyedMohammad​
First let me thank you for posting.
I tried to reproduce the issue mentioned above by following those steps
1- Created a project using CubeMX 6.8.1.
2- Copy this project in order to duplicate it .
3- Open the two projects
==> both ioc files opened successfully , please check the screenshots
_legacyfs_online_stmicro_images_0693W00000bjIr7QAE.pngI will be waiting for your feedback .
Thx
Ghofrane
Hello @Ghofrane GSOURI​
Sorry, I ment on cubeIDE. after copying project file in eclipse IDE. the .ioc file of project no longer works. The bug is on cubeIDE not the cubeMX.
You can easily do this; manually edit the project name in the ioc file and rename the ioc file itself.
Hi @Ghofrane GSOURI​
Was my description, incomplete? If so tell me please.
Manually you can write full x86_64 OS, do it yourself, then! Thanks for workaround.
