2025-01-06 5:20 AM - last edited on 2025-01-06 5:37 AM by Andrew Neil
I am working on USB Device Middleware on STM32F469NI using STM32CubeMX. For our use case we have to modify the PRODUCT_STRING descriptor value (default is "STM32 Virtual ComPort"). Is it recommended to perform this, or are there any STM standards for these values?
Thanks,
Himanshu
2025-01-06 6:12 AM
Of course, you can change PRODUCT_STRING descriptor. Only PID and VID are specific identifiers for USB devices, you can request PID in OLS ticket. Are you sure about your VID 0x0456?
2025-01-06 6:12 AM
2025-01-06 6:55 AM
Hi @FBL,
Thanks for the clarification.
Kindly ignore the modification to that VID and PID in the screenshot as it is temporarily adjusted for our early-stage development with one of our GUIs. Sure, we will raise an OLS ticket if that modification becomes a long-term requirement.
Thanks,
Himanshu
