Micro-SD on STM32H7A3: f_mount returns "FR_NO_FILESYSTEM"
‎2022-03-16 07:39 AM
I have a new project on an STM32H7A3 processor with a microSDHC Card. We want to read/write files with FatFS.
In another project with STM32H7A3 we have SDHC Cards working perfectly.
Code is created with the latest release of CubeMX 6.5.0 and HAL V: 1.10.0.
In the new project we had to use microSD card for reduced space reasons.
With the microSD the call to fmount returns "FR_NO_FILESYSTEM". But on the PC the card is readable and has one folder installed.
I stepped through the source code and fount that the "find_volume" routine returns FR_NO_FILESYSTEM due to "fmt=3" .
Currently we have no idea for a possible solution. The pins are working and pin connection is checked, data is sent/received on the MISO/MOSI lines.
Clockspeed was 25 MHz, reducing to 20 and 16.6 MHz did not solve the problem.
USE_SD_TRANSCEIVER = 0.
Has anybody an idea where to look at further?
Is there any futher switch necessary to specify "micro"SDHC cards instead of SDHC?
Thank you for any comments.
BR GS
- Labels:
SDIO-SDMMC
STM32CubeMX
STM32H7 Series
‎2022-03-16 11:54 AM
Now I got it to work: By disabling the call to SCB_EnableDCache.
With DCache is enabled and even activated chache handling before DMA access the SD card read/write routines don't work.
I am not an expert on the cache handling and therefore I leave it this way with deactivated DCache for now.
Thank you for your hints on these aspects!!! As always: Very much welcome!
BR GS
‎2022-03-16 08:46 AM
Hi
What kind of Micro SD-Card are you using? Do you have it formatted correctly? . Your error code usually means, that the sd-card cannot be initialized due to wrong formatting. Try formatting to FAT/FAT32. If you've got another Micro SD card, give it a try. Also try a non-HC one, if you have got one laying around.
Kind regards and good luck
‎2022-03-16 08:53 AM
Card is a brand new 32 GB SDHC SanDisk card, which I formatted with FAT32. The other card (16 GB SDHC) did not work either. I don't have a NON-HC in house.
Thank you for your suggestions anyway.
‎2022-03-16 09:04 AM
Most SDHC, SDXC in micro and full-size all behave materially the same. Use 512-byte block numbering unlike the sub-4GB cards of yore that used byte level addressing. All microSD cards should be rated to at least 50 MHz.
So using SDMMC (1-bit) or SPI ?
Validate your read/write implementation in DISKIO, if this doesn't retrieve data properly nothing built on top is going to work either.
On H7 be conscious of DMA and cache coherency issues/management.
Polled mode should be impervious to that, but slower.
I'd expect FATFS/SDMMC demo code to be in the Applications directories for the 7A3/7B3 DISCO/DK/EVAL boards. Should port, should be configurable for 1-bit mode.
BR GS
‎2022-05-01 04:21 PM
Here is an instruction on how to do it properly:
