2024-12-18 11:13 PM
Hello! I'm new to the Cube IDE and i want to work with the Chinese board DevEbox with STM32H743VIT6 on it. Before i worked with Arduino Framework where i tested the sd card, ethernet and other basic functions. I wonder, if it and how it possible to use the same DevEbox in Cube IDE as IOC file for example. Should i configure it all by myself or maybe someone has already made and shared it? I would be grateful for any solution.
2024-12-23 06:54 AM
Yes you need to do it yourself based on the board schematics unless the board provider already provided something based on CubeMx.
See also https://community.st.com/t5/stm32-mcus-products/stm32h7xx-board/td-p/641291
Hope that answered your question.
2024-12-23 06:54 AM
