CubeMX USART1 with DMA, LL driver inits DMA streams before enabling DMA CLK
‎2019-12-14 3:31 AM
I have had a problem getting DMA TX for USART1 to work, no errors, stream gets enabled nut nothing is transferred, stream never complets. I am using LL driver for USART1.
I finally found the problem is that generated usart.c code inits DMA without enabling the CLK. Init of DMA is done after USART1. Eventually I found the "hidden" up/down arrows in CubeMX (scroll down the window) and could move call to MX_DMA_Init() up before other peripherals.
I am note sure if CubeMX is supposed to leave such detals to the user - I would not misssed it not using CubeMX but one assumes CubeMX has the brains to handle this dependency, or?
I have CubeMX 5.4.0 and STM32F413 MCU.
Bug-report
DMA
STM32CubeMX
STM32F4 Series
UART-USART
‎2019-12-15 4:31 AM
I can confirm this bug on stm32g4.
MX_DMA_Init should be right after MX_GPIO_Init.
Propably it can affect all cubemx dma code generator.
Pawel
‎2019-12-16 2:21 AM
Similar problems are already tracked in https://community.st.com/s/question/0D50X0000Bmob3uSQA.
The fix will be available in next STM32CubeMX release.
Best Regards,
Amel
