An internal error occurred during: "Launching Src".
java.lang.NullPointerException
‎2023-02-16 7:26 AM
This is using STMCube and an STM32F4-discovery with an STM32f429I
- Labels:
STM32CubeIDE
STM32CubeMX
STM32F4 Series
‎2023-02-20 6:00 AM
Hi @Community member​
It seems that something have corrupt the original workspace.
Concerning the tutorials, I don't know which one you are referring to; but I advice you to give a look to this series.
Best regards,
Semer.
‎2023-02-20 1:58 AM
Hello @Community member​
First let me thank you for posting and welcome you to the community.
Could you provide more detail about mentioned error:
- Which tool version you are using
- The steps you made to get to this error
- The .log file you can find under the workspace in the .metadata folder
- Maybe try to import your project to a new workspace
Kind regards,
Semer.
‎2023-02-20 5:36 AM
Thank you for your response. I have actually gotten around the problem by removing all older versions of the IDE (1.5.1 and 1.11.0), installing the latest (1.11.2), and using a new workspace. Still not a clue as to why I could not, following the steps in the tutorials to create a workspace: identify the discovery board I am using (stm32f4-discovery) or the chip (stm32f429zi6tu), creating the code template, building a debug image, and trying to run the code resulted in the error message I referenced.
Any insight would be appreciated - I am in the process of learning to use the STM32 devices for a research project.
Best,
Dave
‎2023-02-20 6:00 AM
Best regards,
Semer.
‎2023-02-20 9:46 AM
That's a relief, then. I'll just press on with the software tools.
Thanks for the referral to the tutorial series. I am actually using that series. Early days but very useful.
Best regards,
Dave
PS: thank you for the support. I am impressed!
‎2023-02-21 9:36 AM
Hello @Community member​,
Could you please more details about the example you are using? Version of CubeIDE?
It is possible that this is due to a missing dependency or misconfiguration. Try to clean and rebuild the project. If this doesn't help, it could be due to this thread STM32CubeIDE - In-tool update issue! (Solved in 1.11.2)
‎2023-02-21 5:55 PM
I did do a clean and rebuild to no avail. I finally uninstalled the versions I had tried, 1.5 and 1.11, and installed 1.12 and the problem went away.
Thanks for the support,
Dave
