2023-02-16 07:26 AM
This is using STMCube and an STM32F4-discovery with an STM32f429I
2023-02-20 06:00 AM
Hi @Community member
It seems that something have corrupt the original workspace.
Concerning the tutorials, I don't know which one you are referring to; but I advice you to give a look to this series.
Best regards,
Semer.
2023-02-20 01:58 AM
Hello @Community member
First let me thank you for posting and welcome you to the community.
Could you provide more detail about mentioned error:
Kind regards,
Semer.
2023-02-20 05:36 AM
2023-02-20 06:00 AM
Best regards,
Semer.
2023-02-20 09:46 AM
2023-02-21 09:36 AM
Hello @Community member,
Could you please more details about the example you are using? Version of CubeIDE?
It is possible that this is due to a missing dependency or misconfiguration. Try to clean and rebuild the project. If this doesn't help, it could be due to this thread STM32CubeIDE - In-tool update issue! (Solved in 1.11.2)
2023-02-21 05:55 PM
I did do a clean and rebuild to no avail. I finally uninstalled the versions I had tried, 1.5 and 1.11, and installed 1.12 and the problem went away.
Thanks for the support,
Dave
