Debugger is showing signed value for unsigned char
Guven47
Hello guys,
I have a problem like this. How can I fix this problem
24 REPLIES 24
Andrew Neil
Evangelist III
Pavel A.
Evangelist III
Yellow color marks values that changed since last read by the debugger, for example after doing a step or hitting a breakpoint.
SofLit
Do you mean you get a negative value for an unsigned variable?
Yes,I got negative value from unsigned varible. How can I fix ?
The debugger interprets uint8 data as int8
Could you please attach a project reproducing the behavior?
When you created the project, did you change anything in the properties? What version STM32CubeIDE ?
I Can't Believe It's Not Butter. If you find my answers useful, click the accept button so that way others can see the solution.
The configurations are all the same and works properly in Keil.
