Debugger is showing signed value for unsigned char
Guven47
Hello guys,
I have a problem like this. How can I fix this problem
24 REPLIES 24
Pavel A.
Evangelist III
Yellow color marks values that changed since last read by the debugger, for example after doing a step or hitting a breakpoint.
SofLit
Do you mean you get a negative value for an unsigned variable?
PS:
Yes,I got negative value from unsigned varible. How can I fix ?
The debugger interprets uint8 data as int8
Could you please attach a project reproducing the behavior?
PS:
When you created the project, did you change anything in the properties? What version STM32CubeIDE ?
Don't worry, I won't byte.
TimerCallback tutorial! | UART and DMA Idle tutorial!
The configurations are all the same and works properly in Keil.
