Debugger is showing signed value for unsigned char
‎2024-09-18 8:05 AM - last edited on ‎2024-09-19 12:03 AM by mƎALLEm
Hello guys,
I have a problem like this. How can I fix this problem
STM32Cube MCU Packages
‎2024-09-18 8:15 AM
Why is that a problem?
You need to give more detail!
‎2024-09-18 8:55 AM - edited ‎2024-09-18 8:56 AM
Yellow color marks values that changed since last read by the debugger, for example after doing a step or hitting a breakpoint.
‎2024-09-18 9:01 AM
Do you mean you get a negative value for an unsigned variable?
‎2024-09-18 10:27 PM
Yes,I got negative value from unsigned varible. How can I fix ?
‎2024-09-18 10:29 PM
The debugger interprets uint8 data as int8
‎2024-09-19 12:01 AM
Could you please attach a project reproducing the behavior?
‎2024-09-19 12:32 AM
When you created the project, did you change anything in the properties? What version STM32CubeIDE ?
TimerCallback tutorial! | UART and DMA Idle tutorial!
‎2024-09-19 12:42 AM
The configurations are all the same and works properly in Keil.
