Manage embedded software selection not doing anything (CubeIDE on Windows 7)
christophersmith1618
I have an H755ZL and so I downloaded CubeIDE and CubeMX to begin familiarizing myself. I am unable to install the cubeMX H7 package so I cannot generate any code for my MCU. In either CubeIDE or CubeMX when I go to "manage embedded software" nothing happens. I also cannot login as nothing happens when I click that either.
Rim LANDOLSI
Hello @christophersmith1618 ,
CubeIDE is only supported for Windows 10 and 11. So, using Windows 7 might affect the IDE functionality.
Thanks,
Rim.
11 REPLIES 11
SofLit
Hello and welcome to the community.
Could you please share warning or error messages you are facing?
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
There are no warning or error message, no messages of any kind. When I click on the selection in the drop down nothing happens.
Ok not sure I understood the issue.
Do you mean when you want to select "Manage Software Packs" from "Software Packs" menu nothing happens?
In fact this window should show up:
PS:
Yes that is exactly what I mean
Did you try to uninstall/install CubeMx?
Could you please provide the version of CubeMx? which platform?
PS:
I just downloaded CubeMX and CubeIDE so they are the latest versions. I have not tried uninstalling yet. I am on windows 7
Try to uninstall/install it and get back to us with the results.
PS:
This may or may not be the issue, but Windows7 has not been supported since some time before CubeMX version 6.2 (March 2021).  It was supported in CubeMX 5.6, and I don't have any release notes for versions between 5.6 and 6.2.
@Semer CHERNI could confirm this point.
PS:
