Manage embedded software selection not doing anything (CubeIDE on Windows 7)
‎2024-04-05 7:32 AM - last edited on ‎2025-02-07 12:22 AM by mƎALLEm
I have an H755ZL and so I downloaded CubeIDE and CubeMX to begin familiarizing myself. I am unable to install the cubeMX H7 package so I cannot generate any code for my MCU. In either CubeIDE or CubeMX when I go to "manage embedded software" nothing happens. I also cannot login as nothing happens when I click that either.
- Labels:
STM32CubeIDE
‎2024-04-09 4:11 AM - edited ‎2024-04-09 4:12 AM
Hello @christophersmith1618 ,
CubeIDE is only supported for Windows 10 and 11. So, using Windows 7 might affect the IDE functionality.
Thanks,
Rim.
‎2024-04-05 7:38 AM
Hello and welcome to the community.
Could you please share warning or error messages you are facing?
‎2024-04-05 8:15 AM
There are no warning or error message, no messages of any kind. When I click on the selection in the drop down nothing happens.
‎2024-04-05 8:21 AM - edited ‎2024-04-05 8:22 AM
Ok not sure I understood the issue.
Do you mean when you want to select "Manage Software Packs" from "Software Packs" menu nothing happens?
In fact this window should show up:
‎2024-04-05 8:23 AM
Yes that is exactly what I mean
‎2024-04-05 8:25 AM - edited ‎2024-04-05 8:26 AM
Did you try to uninstall/install CubeMx?
Could you please provide the version of CubeMx? which platform?
‎2024-04-05 8:28 AM
I just downloaded CubeMX and CubeIDE so they are the latest versions. I have not tried uninstalling yet. I am on windows 7
‎2024-04-05 8:30 AM
Try to uninstall/install it and get back to us with the results.
‎2024-04-05 1:56 PM
This may or may not be the issue, but Windows7 has not been supported since some time before CubeMX version 6.2 (March 2021). It was supported in CubeMX 5.6, and I don't have any release notes for versions between 5.6 and 6.2.
‎2024-04-05 3:18 PM
@Semer CHERNI could confirm this point.
