Debugger is showing signed value for unsigned char
Guven47
Hello guys,
I have a problem like this. How can I fix this problem
24 REPLIES 24
I tried what you said but the problem is not solved. Works properly in Keil
I I use version 13.0.2
I tried what you said but it didn't solve the problem.
Tried what?
I asked you to attach a minimal project that reproduces the behavior in order to replicate the same behavior from our side.
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
Of STM32CubeIDE?
Try the latest version 1.16.1
What year was that version released? 2075?
What tools are you using?
Tips and Tricks with TimerCallback https://www.youtube.com/@eebykarl
DaveJ
You can right on the value field and pick "Cast to Type" and then type e.g. uint32_t or whatever you want.
You're not getting the point. The OP is already showing the variable as uint8_t but the value is showing as negative (-128)
Plus the OP is in Live Expressions and unless you know of a trick, you can't change the type
Does this also happen in the 'Variables' view?
Yes,it's happening.
