Change target microcontroller
pass3master
Senior
This is a question about STM32CubeIDE.
When creating a new STM32 project, you select the board, but if I select STM32F412 and edit the program, can I operate the STM32H743 microcontroller?
(We will adjust the pin configuration accordingly)
I've moved it to the STM32CubeIDE section, then. And updated the title.
To change the Target microcontroller, See the answer here:
https://community.st.com/t5/stm32cubeide-mcus/how-to-change-hardware-target-on-stm32cubeide-we-have-source/td-p/122794
3 REPLIES 3
STTwo-32
Hello @pass3master
Could you give some more details.
Best Regards.$
STTwo-32
Thank you for your reply.
We understand that the hardware target cannot be changed,
so we will consider this problem solved.
