2023-03-19 4:18 AM
When I insert a breakpoint or pause the debugger, the debugger first stops at a point where there was probably an ISR, showing the error message in the figure below, and I need to press F5 again so that the degugger goes to the breakpoint that I inserted.
2023-03-23 4:21 PM
I've seen this occasionally as well. Can you please report this issue to our Embedded Tools issue list as it is coming from our debugger integration.
2023-03-23 4:21 PM
