STM32 MPUs Products and hardware related
Ask questions and find answers on STM32 microprocessors, including hardware, power, DRAM, flashing, interfacing, device tree, and peripherals.
Resolved! Engineering mode and CA7 secure state
In RM it is stated that in Engineering mode (BOOT pins at 3'b100) the MPU re-opens CA7 secure debug.I boot in that mode, then halt in openocd:stm32mp15x.cpu0: hardware has 6 breakpoints, 4 watchpoints > halt stm32mp15x.cpu0 rev 5, partnum c07, arch f...
Is it possible to compile LinuxPTP with the OpenSTLinux Developer SDK or will OpenSTLinux eventually include LinuxPTP?
I am having issues cross-compiling LinuxPTP. I've been able to work my way through some of the cross-compiling issues but now I am stuck with the compiler searching for crt1.o, crti.o and crtbegin.o files. Any help would be appreciated.
Resolved! linux performance
I just got my dk2 kit, played with it a little bit, but the performance is so bad. it takes a lot to boot ~30sec and after that it is unresponsive, you click something, then several seconds later something happens. Is this considered normal, or it is...
Resolved! OPTEE, trusted APPS
I'm interested in learning about TF-A, OPTEE, are some demos concerning these topics available?Is it possible to debug the CortexA core, through the embedded ST-LINK? I mean working solution, not in theory?What would be limitations debugging very ear...
4 questions about "st-example-image-qt"
Hello,I have 4 questions if you have time to answer, I would appreciate it very much.I prepared st-example-image-qt image. But there isnt any terminal like weston image. Should I run any other command before bitbake in order to have all the tools pac...
IYetk by Associate III
  • 2207 Views
  • 4 replies
Resolved! Display in separate module
Lets say I need to separate module, one will contain the pcb with mpu and other IC, the second will contain a touchscreen display and sensors. The modules are 2 meters apart. What should I use hdmi or mipi? How do I send mipi over distance?
GEspi.19 by Associate
  • 1065 Views
  • 1 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
