STM32 MPUs Products and hardware related
Ask questions and find answers on STM32 microprocessors, including hardware, power, DRAM, flashing, interfacing, device tree, and peripherals.
DDR addr bus test Error in STM32MP153A
We modified the device tree file corresponding to our development board based on stm32mp157d-ev1.dts.We did not use a PMIC chip, so we added our own power node and modified the default serial port output.This is my device tree file:The following erro...
DG by Associate II
  • 2134 Views
  • 3 replies
STM32MP151 change default UART
We want to change default uart from UART4 to UART8,from:aliases { ethernet0 = &ethernet0; serial0 = &uart4; .... };we changedserial0 = &uart8;and implement uart8 as below:&uart8 { pinctrl-names = "default", "sleep", "idle"; pinctrl-...
Dat Tran by Senior II
  • 1221 Views
  • 1 replies
Resolved! How to set "TRUSTED_BOARD_BOOT=1" without "TF_A_SIGN_ENABLE=1" with yocto build?
Hi @OlivierK​ ,I am using openstlinux ecosystem release v3.1.1 and trying to use secure boot feature with yocto and as per https://wiki.st.com/stm32mpu-ecosystem-v3/wiki/TF-A_overview we need to set "TRUSTED_BOARD_BOOT=1".We need use "TF_A_SIGN_ENABL...
GChin.1 by Associate II
  • 2893 Views
  • 1 replies
Resolved! extlinux.conf can't chose uInitrd boot
hi st expert​I am porting openstlinux for my robot board, I found that the system froze after uboot selected the extlinux file, and then rebooted after a while,the uart log :Do I have any debugging means to analyze where the current problem is? than...
ttao.1 by Associate II
  • 2263 Views
