SOLVED: Compiler errors in CubeIDE with STM32F469I-DISCO
mandrake
Can someone please test this?
TouchGFX 4.18.0
STM32CubeIDE 1.8.0
STM32F469I-DISCO
Create a simple screen on TouchGFX and try to compile the project on CubeIDE.
You would expect this to work "straight out the box". I am getting compile errors.
This is surely a code/library configuration bug.
There is no problem with STM32F746G-DISCO.
mandrake
PROBLEM SOLVED
Holy mackerel! Thanks to @ilyus​ for asking the same question 5 days ago. I've lost weeks struggling with this issue.
Why doesn't ST inform users about this problem and the simple fix?
You would think that ST should just remove v 3.0.5 from the Versions list. Then users would not be in this situation.
SOLUTION:
When you select the STM32F469I-DISCO board in TouchGFX, before clicking on create, select Version 3.0.4.
mandrake
PROBLEM SOLVED
SOLUTION:
0693W000008y9fZQAQ.png@mandrake​ : "PROBLEM SOLVED"
