In center align mode SPWM generation may I need give the same CCR value in the LUT
‎2024-08-27 08:08 AM
Hi ,
In SPWM generation ,in Center align mode ,May i require give one sine table value twice , in the upword and down counting sequence .
Original sine wave values: [A1, A2, A3, ..., A200]
DMA array: [A1, A1, A2, A2, A3, A3, ..., A200, A200]
like wise the DMA array ?
other wise is it distroted ?
DMA
STM32F4 Series
TIM
‎2024-08-28 02:23 AM
In center-aligned PWM mode, the counter counts both up and down within a single period. This means that each value in the sine wave table will be used twice: once during the up-counting phase and once during the down-counting phase. I think you should try to provide each sine table value twice in the DMA array
‎2024-08-27 08:15 AM
It depends on how your values are generated, but you are not required to duplicate values and doing so will make your sine wave more distorted, in general.
‎2024-08-27 08:28 AM
if it duplicate , in one pwm cycle there are two ccr value , is it distrote the wave . please how do i to get a smooth sinewave ?
