how to configure HSI in STM32L5...
DYann.1
Senior II
I would like to know if it's possible to configure my evaluation board HSI, I have this code and I would like to adapt it on my evaluation card and see if it is compatible with the rest :
// HSI
void SystemClock_Config(void)
    RCC_OscInitTypeDef RCC_OscInitStruct =
	0
    RCC_ClkInitTypeDef RCC_ClkInitStruct =
	0
    if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE0) != HAL_OK)
	Error_Handler();
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI
	    | RCC_OSCILLATORTYPE_HSI48 | RCC_OSCILLATORTYPE_LSE
	    | RCC_OSCILLATORTYPE_LSI | RCC_OSCILLATORTYPE_MSI;
    RCC_OscInitStruct.LSEState =  RCC_LSE_BYPASS;
    RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
    RCC_OscInitStruct.LSIDiv = RCC_LSI_DIV1;
    RCC_OscInitStruct.LSIState = RCC_LSI_ON;
    RCC_OscInitStruct.MSIState = RCC_MSI_ON;
    RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
    RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
    RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
    RCC_OscInitStruct.PLL.PLLM = 2;
    RCC_OscInitStruct.PLL.PLLN = 23;
    RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV8;
    RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
    RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV7;
	Error_Handler();
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
	    | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
	Error_Handler();
    /** Enable MSI Auto calibration
    HAL_RCCEx_EnableMSIPLLMode();
    /** MCO configuration
    HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_SYSCLK, RCC_MCODIV_1);
    //__HAL_RCC_PWR_CLK_ENABLE();
With the .ioc file, it's better for understanding.
Thank you for your helps.
22 REPLIES 22
@Andrew Neil wrote:
Were you sure to save those settings, and to re-generate the code?
Please post the .ioc file.
Really ? You don't have the .ioc file in my _HSI_conf.zip ? When I unzip my file
I can see the .ioc file
When I open the projet I can see the Clock configuration under STM32CubeIDE
@Andrew Neil wrote:
PS:
As @TDK noted earlier, are you sure the code that you showed relates to the System clock - not the RTC ?
Show the full code.
What the full code ? I have the code at the beginning of my message but no .ioc file and I would like to create an .ioc file with the same code, just for void SystemClock_Config(void) for this moment and nothing else
That was attached several posts earlier - has it not changed?
No,
RCC_OSCILLATORTYPE_LSI is missing.
The original code is
And I have this code with my .ioc file :
(never mind)
I'm confused.
You attached your zip file to this post:
https://community.st.com/t5/stm32-mcus-products/how-to-configure-hsi-in-stm32l5/m-p/755458/highlight/true#M269041
In your next post, you said:
@DYann.1 wrote:
After making the changes ...
Here: https://community.st.com/t5/stm32-mcus-products/how-to-configure-hsi-in-stm32l5/m-p/755630/highlight/true#M269063
That's the post I was replying to when I asked for .ioc file & full code - ie, the stuff after you made those changes.
@Andrew Neil wrote:
The .ioc file just saves the CubeMX configuration - the C source code has to be generated from that configuration data.
So how to configure CubeMX to have this code ?
It's the same question but asked in reverse.
@Andrew Neil wrote:
I'm confused.
I have only this code without '.ioc'
// HSI
	0
	0
	Error_Handler();
	Error_Handler();
	Error_Handler();
And I would like to have the .ioc file to look at the configuration and adapt to my code, thus I created a _HSI_conf project to have the .ioc file in order to generate the code that I found. Now do you understand what I'm looking for ?
So post that .ioc file, and the code that was generated from it - the most recent version, after all the changes that have been discussed.
@Andrew Neil wrote:
So post that .ioc file, and the code that was generated from it.
???? Is this a joke ?  With all these explanations and you going around in circles ?
You said you'd made changes since the zip file you posted.
Anyhow, I'm out.
