DevEbox in CUBE IDE
  • December 19, 2024
  • 1 reply
  • 1360 views
Hello! I'm new to the Cube IDE and i want to work with the Chinese board DevEbox with STM32H743VIT6 on it. Before i worked with Arduino Framework where i tested the sd card, ethernet and other basic functions. I wonder, if it and how it possible to use the same DevEbox in Cube IDE as IOC file for example. Should i configure it all by myself or maybe someone has already made and shared it? I would be grateful for any solution.
Best answer by mƎALLEm
Yes you need to do it yourself based on the board schematics unless the board provider already provided something based on CubeMx.
See also https://community.st.com/t5/stm32-mcus-products/stm32h7xx-board/td-p/641291
Hope that answered your question.
1 reply
mƎALLEm
mƎALLEmBest answer
