.HEX file expiry date
NANWA.1
Dear Team,
Can we set the expiry date of .HEX file?
Regards,
N.Anwar
SofLit
No you can't.
You can maybe program your expiry date into the flash and use RTC and each time in your application you need to compare the current date to what programmed into the flash and do what you want to do: don't run the application or whatever ..
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
3 REPLIES 3
Peter BENSCH
For what purpose would such an expiry date be useful?
/Peter
No, you can't set an expiration date on a HEX file.
SofLit
No you can't.
PS:
