2020-02-19 07:53 AM
So, which is correct and which is wrong?
The same is in RM313 for 'F37x.
Would those who wrote/modified AN4232 pay more attention to checking the facts through actually writing test cases, rather than applying the "modern feel and look", this must have caught their attention.
AN4232 should also mention the dramatic increase in power consumption of the COMP modules in 'G4, compared to 'F3.
@Vincent Onde - a prime example of why it's in ST's interest of write dozens of appnotes per module, together with concise software examples; instead of just copy/pasting from RM and rephrasing.
2020-02-24 03:17 AM
Hello Jan,
I raised the problem internally for correction.
Best Regards,
Imen
2020-02-20 12:14 AM
Hello Jan,
Thank you for your remark.
I will check it and get back to you
2020-02-24 03:17 AM
Hello Jan,
Best Regards,
Imen
2020-02-24 03:19 AM
Thanks, Imen!
Jan
@Imen GH
2020-04-04 06:03 AM
2024-05-24 01:51 AM
2024-05-24 02:11 AM
Hi @waclawek.jan,
Thank you for pointing out this missing.
I will push to correct this in the next release.
