Can someone help me with RTC clock
Kai_Satone
Hello everyone,
I want to Know if I can set RTC on "6" different time.
Through the Day .
Help with exampl.
Thank you.
You need to manage this by software. There is only one counter in RTC.
You set the RTC by GMT time and display the local time by adding +/- T (time offset) for each time zone.
See these threads:
https://community.st.com/t5/stm32-mcus-products/function-library-to-convert-between-utc-time-and-local-time/td-p/211219#:~:text=The%20STM32%20has%20no%20way,out%20of%20the%20embedded%20system.
https://community.st.com/t5/stm32-mcus-products/add-date-time-offset-set-time-zone/td-p/218010
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
3 REPLIES 3
Which STM32?
What do you mean by 6 different times? Do you want to display simultaneously time in 6 different timezones, like time in Tokyo, Kuala Lumpur, Los Angeles, New York, London, Kyiv, at the same moment?
@waclawek.jan
yes
See these threads:
