ST Motor Pilot/Profiler will not connect when using UART.
‎2025-03-06 3:58 PM
Hello, I have a custom motor controller that I've developed that uses the STSPIN32G4. After a bunch of goof ups I finally managed to get it configured, presumably correctly, in the MC Workbench Board Designer. However once I upload the compiled program to the board, I cannot connect to it using the motor profiler or motor pilot software. I have checked that I have the right baud rate (115200), I've enabled motor profiler in the project, and I've tested my UART connection with CubeProgrammer (which functioned as expected).
I'm wondering what the issue is? My assumption is that if I have UART communication at the correct baud rate with CubeProgrammer, then the only issue could be in software somewhere because ASPEP just isn't getting a response beacon. My assumption could be totally wrong though and I could have also configured something wrong in hardware. Just let me know if you have any ideas as to what could be going wrong, or if you need any more information to diagnose. Thank you!
‎2025-03-12 4:56 AM
‎2025-03-12 10:13 AM
Hello @dfshea,
Bus voltage feature has to be defined on your board description and aligned with your hardware (EVSPIN32G4 example):
If TIMx_BRK_M1_IRQHandler() is called, you have to check why OCP occurred. Check if the Current Sensing Hardware Variant parameters (gains, shunt) are aligned with your HW, verify the RShunt voltage level, ...
Your last attached zip file is empty.
Best regards.
GMA
‎2025-03-12 11:25 AM
I’m not sure that interrupt is getting called, I put a breakpoint there and it didn’t stop. I also don’t have OCP turned on so why would it be triggering OCP?
‎2025-03-12 12:30 PM
I have some info that might be helpful that I just found out: the code (in debug mode) runs totally fine until I try to connect over UART. For example if i pause the program, the pointer goes to the while loop, however as soon as I try to connect over UART it breaks, I press pause and get the error message below:
- « Previous
- 1
- 2
- Next »
